by: Mike-SW
#28445
Thank you! Now I don`t need to use -f! Downgrading to Enoch 2889 resolved blank verbose problem. The only problem left unsolved is Chrome. I can`t imagine what causes it to sign me out (Sign-In details are out of date) every time I restart. Anyway, while fiddling with loaders and recovering OS partition from backup image I accidentally removed 200 mb EFI partition, is it critical? Do I need it at all?
by: Norton287
#28447
Not really only if you installed Enoch into to EFI
Here's an update org.chameleon.boot.plist file extract it and overwrite your old one. I'd make a backup of your old one first.
(1.04 KiB) Downloaded 28 times
by: Mike-SW
#28596
I guess I found where the chrome problem stems from - it`s keychain. I earlier noticed that I have some saved logins which I don`t have on other chrome installations. After I reset chrome and delete it from keychain - everything is fine, I can see my typical saved logins and passwords, but after restart I have this "sign-in detail are out of date" problem and a lot of old logins and auto-saved form details. So, the question is - can I disable keychain for chrome. Or maybe totally turn it off?
by: Norton287
#28597
You should be able to, look at your icloud settings for keychain
by: Mike-SW
#28673
Finally got rid of this stupid problem, all you need is to allow all applications to access chrome safe storage in keychain. Hope it`ll help someone, this issue was driving me mad.
Screen Shot 2017-10-03 at 21.33.36.png (526.19 KiB) Viewed 331 times
by: Norton287
#28674
Glad you fixed it and thanks for the info :thumbup:
