by: loong4455
#25806
Hi, i've successfully installed el capitan on my pc, but i have several problems, only 1 of my usb ports are detecting my usb drive but mouse and keyboard are working on any ports, i have installed the usb fix from shaneee using kext utility. Next, my graphic card is not working with a 3mb video detected and stucked at 1024x768.
Here are my system specs.
AMD athlon X6 1055t
Asus M5A97 R 1.02
8GB DDR3 RAM
Sapphire R5 250 1GB
1TB HDD
edit 1: reinstalled everything, installed the lastest voodoohda and sound is working, tried to install clover with fake id and inject ati but when i press boot from my hdd it give a error code in red with a line starting X64 exception type 00000006. Installed sparkk and shaneee usb fix and only certain ports are working for mouse keyboard and usb
#25950
Try installing this USB fix, viewtopic.php?f=23&t=2073
You'll need to restore the original USB kexts first. The easiest way is to clean install. Clover won't work I'm afraid so just use Enoch. Once USB is working we can work on the GPU.
by: loong4455
#25988
@Shaneee, hi, all the ports are working after a clean reinstall with the usb fix, now only the graphic problem remaining
#26205
Open System Information and send a screenshot of the Graphics section.
by: loong4455
#26237
@Shaneee, here you go
Display:
Type: GPU
Bus: PCIe
PCIe Lane Width: x4
VRAM (Total): 3 MB
Vendor: ATI (0x1002)
Device ID: 0x6610
Revision ID: 0x0000
Kernel Extension Info: No Kext Loaded
Displays:
Display:
Resolution: 1024 x 768
Pixel Depth: 32-Bit Color (ARGB8888)
Main Display: Yes
Mirror: Off
Online: Yes
#26496
Ok try installing these kexts using Kext Utility,
by: loong4455
#26548
@Shaneee, hi, it didnt work out, black screen or sometimes white screen with black stripes. And i forgot to mention my motherboard x16 slot is faulty so my graphic card is at second pcie slot which is x4 mode
by: SomeOne874
#44561
@Shaneee, Hi I installed and I run the post.sh script. But fail at line 42: permission denied. LINE 42: rp -r /Volumes/"$VOLUME"/ # Repair Full Drive Permissions
What can I do to give permission on bash on the installer El Capitan v2? Thanks!!
