by: dsalsa
#1274
I need some assistance please. I just re installed El Capitan on my SSD and I wanted to add the boot flags "GraphicsEnabler=Yes " so that I wouldn't have to type it in every time I booted my computer. To my big surprise there is no Extra folder. I checked on my old El Capitan installation which is on another ATA drive and it does have the Extra folder. So here is where I need your help. Could you tell me where my Extra folder would be so I could add the "GraphicsEnabler=Yes" to my boot flags so that I don't have to type it in every time I boot my machine,
Thank you.
#1276
It isn't created by the installer. You will need to create or copy on there.
You can get my Generic Extra folder here,
http://nova-x.co.uk/download.html
by: dsalsa
#1331
Shanee after reviewing the org.chameleon.Boot.plist in the Generic Extra folder it's still missing the one boot flag I need "GraphicsEnabler=Yes". Can I open the file with the text editor and just add it to the <string> line and then just copy the Extra folder to the appropiate drive?
Alternatevely can I use the Chameleon Wizard even though I'm not using Chameleon I'm using Enoch?
P.S. just noticed the org.chameleon.Boot.plist on my old El Capital installation the "GraphicsEnabler" it's not in the <string> line but a <key> line and then the "Yes" in another <key> line, then I thought wouldn't the easiest and simpler to just copy the Extra folder from my old El Capitan to my new El Capitan. Can't get easier than that.
#1332
Yes you can add it in or use Chameleon Wizard. The correct way to add it is,
	<key>GraphicsEnabler</key>
	<string>Yes</string>
by: dsalsa
#1383
Thank's, added
to my org.chameleon.Boot.plist, saved the Extra folder on my drive and it works like a charm.
#1384
Great, glad it's working now :thumbup:
#51347
abhi_rozz wrote:Please share the extras folder link
Anyone please
No idea why you'd still need this tbh but it's here, https://files.amd-osx.com/GenericExtra.zip
