by: MacMan
#1010
Well El Capitan installed successfully. Kernel Panicked, but I figured that out. No internet, but I got that sorted. I still don't have audio, but I don't think that will be a big deal... hopefully.... I have one (sorta) major problem left thought...
Every time my computer boots, it resets my CMOS. I then have to load my "last working settings" and reboot again to start up. Anyone have any thoughts?...
....also, It won't boot when I have 3 monitors plugged in at the same time... but i haven't spent any time trying to figure that out, and i feel thats much lower on the priority list, Still if you know an answer that will save me future head scratching time, it would be much appreciated :) :thumbup:
#1020
For your CMOS reset you can try patching AppleRTC.kext with the following code in terminal,
sudo perl -pi -e 's|\x75\x2e\x0f\xb6|\xeb\x2e\x0f\xb6|' /System/Library/Extensions/AppleRTC.kext/Contents/MacOS/AppleRTC
sudo touch /System/Library/Extensions
by: 6for6
#1023
I was just going to make a new thread about cmos reset but it is already here.
I applied usbfix v3 to s/l/e and at least usb 2.0 ports work at its own speed. Audio works with voodoohda.kext from niresh mavericks. I solved wireless network problem with buying asus n10 nano receiver but connection keeps being interrupted. Sometimes it lasts long sometimes it doesn't. Now i am on el capitan. Itunes(playing songs) and photos crashes with kernel error. i am sharing "photos error log" below.
the most disturbing thing at the moment cmos reset at system restarting and shutdown. This way at every startup of osx system clock resets. It is so annoying.
Process:               Photos [512]
Path:                  /Applications/Photos.app/Contents/MacOS/Photos
Identifier:            com.apple.Photos
Version:               1.3 (350.23.0)
Build Info:            PhotoApp-350023000000000~4
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Photos [512]
User ID:               501
PlugIn Path:             cl_kernels
PlugIn Identifier:       cl_kernels
PlugIn Version:          ??? (???)
Date/Time:             2016-04-04 23:29:54.042 +0300
OS Version:            Mac OS X 10.11.3 (15D21)
Report Version:        11
Anonymous UUID:        5D33551E-6F92-43FD-FB3C-E95DFB5223C2
Time Awake Since Boot: 160 seconds
System Integrity Protection: disabled
Crashed Thread:        16  Dispatch queue: com.apple.root.default-qos.overcommit
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0xffffffff20316040
Exception Note:        EXC_CORPSE_NOTIFY
VM Regions Near 0xffffffff20316040:
--> shared memory          00007fffffe49000-00007fffffe4a000 [    4K] r-x/r-x SM=SHM
Application Specific Information:
Photo Foundation logging:
2016-04-04 23:29:52.421: Received changes notification alert: <LiModelChangeGroup: 0x7fe1c85793f0>  alert flags : Replay Complete (__59-[RKFaceChangesHandler startListeningForChangesFromMarker:]_block_invoke_2:173)
by: MacMan
#1024
:) Shaneees code fixed the resets for me. Thanks a ton! @6for6 I followed this youtube video :
and its linked download fixed my ethernet... thanks for the audio tip.
Last edited by Shaneee on Tue Apr 05, 2016 12:18 pm, edited 1 time in total. Reason: Added Video Inline
by: 6for6
#1026
i tried that code and at first trial it didnt work. I tried again and some other things like osx shutdown fix.dmg worked.
i ll check video out.
