by: kore44110
#7782
Fx-6300 using USB Boot
-f -v PCIRootUID=1 USBBusFix=Yes
How can I Fix this?
thx
#7783
Take a look here, viewtopic.php?f=23&t=196
by: kore44110
#7784
Shaneee wrote:Take a look here, viewtopic.php?f=23&t=196
Thx Shaneee boot loop is solved but this is my new problem
#7785
Boot with just -v USBBusFix=Yes nv_disable=1
by: kore44110
#7786
Shaneee wrote:Boot with just -v USBBusFix=Yes nv_disable=1
Thanks you but still no changes
#7787
Try with -x -v USBBusFix=Yes GraphicsEnabler=No nv_disable=1
#36290
Cantero wrote:
Shaneee wrote: Sat Oct 01, 2016 1:35 pm Take a look here, http://forum.amd-osx.com/viewtopic.php?f=23&t=196
Topic deleted. I have the same problem, please help
Updated version here, http://forum.amd-osx.com/viewtopic.php?f=23&t=2073
by: ozomatzinboy
#45094
@Shaneee, hi Shanee, thanks for all your wonderfull help...i was looking for the link to the start stop usb bus loop fix but its not any more...i am trying to install with your sierra v 5.2 in an fx 8350 in gigabyte usb3.0 mobo, and i am stuck in this loop...please help...thankyou very much...¡¡
