by: kingCosmo
#45692
SPEC:
AMD PRO A8 -8600B with AMD Radeon R6 Graphics
12GB ram
So I found this laptop, and because I've been thinking about making a hackintosh, i decided to try this laptop.
Problem 1: The device has no USB 2.0 ports
Solution: I created the bootable installer on a hard drive
Problem 2: Install screen is asking me to connect a magic mouse, there are no buttons on the screen, trackpad and keyboards (even external) not working.
Solution: I found some kexts including the voodoo ps2 controller, whatevergreen and 4 others. This also fixed the graphical glitches.
I can now boot into the installer, and Install el Capitan. The installation is complete and it asks for a reboot. I reboot the system to the disk with the fresh install and am greeted with a black screen.
I tried:
Using different flags, with varying levels of success - the furthest i got was to (in the verbose)
Mac framework successfully initialized ...[PCI configuration begin]
after which the screen froze.
Importing the kexts I used on the installer on the installed mac os
Unfortunately, these didn't work, but I am not one to give up, so if anyone can help, please leave your suggestions.
thanks y'all
