#45033
(New in this Forum)
amd os x el capitan v2 image after the installation of a successful installation after the installation I want to boot the disk when I want to reboot after the image in the image and I can not open the system
cpu: amd fx 6300
motherboard: ga-970a-ud3 (rev 3.0)
graphics: AMD HD 7790 2GB OC
RAM: 8GB DDR3
HDD: 1 TB
#45034
See this post for setting up the installed system for AMD once it's installed, viewtopic.php?f=24&t=80
#45043
Boot with UseKernelCache=No
#45045
Why El Capitan though? You can install High SIerra.
#45046
I can't get to the setup screen when I want to install high sierra ++++++
I want to use high sierra if you can help if you don't bother
Shaneee wrote: Wed Jan 23, 2019 5:32 pm Why El Capitan though? You can install High SIerra.
https://hizliresim.com/grW392I get this error before I can access the installation screen when installing high sierra
