by: redband123
#4609
I see that the AMD kernel has been updated to Darwin 15.4.0.
Can you tell us if it improves performance, loading and stability for an AMD Athlon II CPU?
Is the Shaneee-10.11.x-RC2 from the Download page the Darwin 15.4.0 update. If not where to download same.
Is it possible to use the same kernel for an upgrade from El Capitan to Sierra 10.12? Anyone tried it yet
Mike
#4622
It makes the system a little more responsive. It fixes the issue where Helper Tools wouldn't install.
The kernel won't work on Sierra. Need to wait till Apple release the source code for the kernel.
Edit: Here is RC3 built to Darwin 15.5.0. I'll upload it to the downloads page soon.
Darwin Shaneees-Pro 15.5.0 Darwin Kernel Version 15.5.0: Sat 23 Jul 2016 21:59:51 BST; root:xnu-3248.50.21/BUILD/obj/RELEASE_X86_64 x86_64
(4.16 MiB) Downloaded 36 times
by: redband123
#4686
O.K. Thanks for the updated kernel.
Just one thing - what are the files in the System folder?. Do I put all these files in S/L/E and replace any that maybe there, or, what?
by: Valkiry
#4690
redband123 wrote:O.K. Thanks for the updated kernel.
Yes place in S/L/E and repair permissions with KCPM utility and rebuild cache.
#4695
It's not a System folder it's one kext that contains others. Install the System.kext into S/L/E and the kernel to S/L/K and rebuild the prelinkedkernel.
by: achamate
#4701
Prelinked kernel is the same as fixing permission with kext wizard or EasyKext?
#4703
Not sure about EasyKext but kext wizard won't do it on El Capitan. Kext utility will but so does the terminal commands.
by: achamate
#4705
I will never use terminal again jajajaa. Just kidding. Anyway, Easykext pro only works in Capy, the thing is you better wait until its says COMPLETED in notifications or system becomes corrupted. Oh my patience!
#4707
I prefer terminal as I know what it's doing. Kext utility is good or KCPM Utility if you want ease of use.
