#4246
I've been looking everywhere but I can't seem to find what to do after installing and booting into my disk. I am now in the Mac OS desktop. Do I need to install Enoch onto my disk? If yes, which settings do I choose? Card is 7950. Also, do I need to re patch kernel after installing boot loader? Then, how do I install kexts? Do I need to do the signature thing or I can use the amd installer that I've downloaded from here? Then, how do I install kexts? Just double click or I need to drop them somewhere? Sorry they might be a lot of questions but I tried looking them up and had no results.
#4247
Remove EVoreboot kext
#4248
gonza211 wrote:This is what I get now after installing boot loader and amd installer pack.
Remove EVoreboot.kext.
You shouldn't have installed the amd pack kexts yet. If you could boot to installer and login after install you shouldn't have installed them at all, unless it was needed to get to install. Can you explain to me what you did as best you can. Don't get too complicated just tell me how you did your usb installer and if it worked
#4254
EvOReboot isn't compatible with El Capitan. You can get the latest version of Enoch here,
http://www.insanelymac.com/forum/files/file/71-enoch/
Copy the Extra folder to the desktop. Install Enoch then add your Extra folder back replacing the one made by the installer.
#4256
I did the USB installer by watching the video from shaneee. Then patched with USB fix v3. Install was flawless, copied kernel and rebuilt cache. I can boot to El Capitan via the USB with no boot flags (which I assume is good). Set up my account and every time I installed Enoch on the drive that I installed El Capitan I was not able to boot afterwards (even after fixing boot0).
After booting and setting up account I want to make Ethernet and sound working. (Maybe wifi and Bluetooth too). I do not know what to do or how to install Enoch in order to boot directly from the HDD. Neither how to install kexts to make those items work. (Or which)
#4257
Enoch needs to be installed onto the first partition of the drive or if you customise the install you can install it to the ESP ( EFI Partition ) as long as Windows isn't installed on the same drive.
What is your Ethernet device? Also the Wifi - Bluetooth card?
#4258
Shaneee wrote:Enoch needs to be installed onto the first partition of the drive or if you customise the install you can install it to the ESP ( EFI Partition ) as long as Windows isn't installed on the same drive.
OK great. So after I boot into my HDD via the USB and create my account and finish setting up OS X I need to install enoch onto my HDD. Do I need to set any specific settings on Enoch? Also, do I need to repatch the kernel or just copy the Extra folder? (Where to copy the extra folder?).
Wifi card is just a USB Dongle, same as Bluetooth. Both USB Dongles. I have Magic Keyboard and Magic Trackpad 2 and wanted to connect those via Bluetooth. If there are no kexts for bluetooth do I need any to connect them via USB? I assume they should be native.
Bluetooth is :
https://www.amazon.com/gp/product/B00JN61P1U/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Wifi is:
https://www.amazon.com/gp/product/B01D2M30X6/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Last edited by Shaneee on Mon Jul 18, 2016 12:31 pm, edited 1 time in total. Reason: Link coded
#4260
No need to redo the kernel. The Extra folder goes to the root of the HDD. You may need to open the Finder prefernces and allow all HDDs to show in the Sidebar,
Not sure about the Bluetooth, does it show in the System Information? Try this for your WiFi adapter,
(8.93 MiB) Downloaded 38 times
#4262
Great. last thing and i'm off to try everything. Could you help me last with audio, ethernet and graphics cards kext? Motherboard is ASUS M5A78LM/USB3 and Graphics Radeon HD 7950.
Last thing: how do I install kexts? Just drop them on S/L/E con my HDD?
#4263
To install kexts download the app linked below. Drag and drop kexts onto the App icon to install,
http://cvad-mac.narod.ru/index/0-4
Install this kext for Audio,
http://amd-osx.com/files/VoodooHDA.kext.zip
Your graphics should in theory be working. What shows in System Information?
