#4196
Hi there! I'm getting the Please switch to XPC or bootstrap_check_in ERROR.
I don't know what to do from this point. I tried everything. I have the USB Fix and nothing more. I used Pandora's Box to make the USB. I use the Download section Kernel. What can I do?
#4204
Try this kernel instead,
http://amd-osx.com/files/archive/10112R2.zip
#4223
Thanks! Do you have any idea why my USB becomes only readable and no write able after I boot it for the first time? Like, I have to redo the USB INSTALLER everytime i wanna change something. Is Pandora's Box an issue? I'll reply once I use the kernel.
#4228
How do you mean? If you'r copying 'System' files then you need to enter the password for security if that's what you mean.
#4229
Now I'm on this loop..And also, that is the error I get whenever I try to plug in m USB after booting it, it's frustrating I have to remake the installer everytime I open yosemite.
Screen Shot 2016-07-17 at 23.50.23.png (78.23 KiB) Viewed 555 times
#4233
Never seen that happen before. Try this method instead, viewtopic.php?f=23&t=404
