by: WolfDemonX
#239
hello and welcome.
I have installed El Capitan on this configuration:
CPU-Amd APU A8-6600K 4x3.9
GPU-Geforce 750 TI
Ram-GoodRam 1x8gb 1600 Hz
MB-MSI A68HM-E33
with these boot flags :
-v nv_disable=1
When i try to boot everything works fine but after "Patching kernel" and this little 0 animation loading my pc reboots itself.
I followed this http://forum.nova-x.co.uk/viewtopic.php?f=25&t=27 and i did go through but after few more i got stuck on http://imgur.com/kveheyU . i dont know what i need to do.i have copied kernel to kernels on hdd after installation and extras folder to root too. I hope u can help me. in the meantime i will test other kernels :)
I manage to boot with other kernel
http://www.hackintosh.zone/file/899-el-capitan-amd-kernel-10110-10111-10112/
but what about post installation cause when i used multibeast with easy beast ( clover :( ) and installed my audio and ethernet drivers i got kernel panic.
UPDATE!
my sound is not working
my sound card is realtek ALC887
and symbol on osx are some kind of graphic glitched there was a post of it in post installation
ive already installed the nvidia web driver but cant get my resolution 1440x900 idk how exactly
now im installing enoch
#242
Ok this is the most current stable kernel so use this one, http://forum.nova-x.co.uk/viewtopic.php?p=66#p66
As for your post installation, remove any changes made with the multibeast thing we don't need it ;) Once you're booted to the desktop let me know what isn't working and we can go from there :)
Edit: Also please use the edit button to edit your post rather than adding another post directly under one of your own.
WolfDemonX wrote: UPDATE!
You can add a new reply. I meant to use the edit button if there is no reply to avoid "double posting"
Upload your original AppleHDA.kext for me to patch. Can you add a screenshot of the glitches?
Once the Web Drivers were installed did you add the bootflag nvda_drv=1
by: WolfDemonX
#246
yes its is added by default i will add this apple.kext shortly but not today .
For that graphic glitches http://imgur.com/oxxJbFR look up at the app store where is written kategorie uaktualnienia ( this is in polish cause i come from poland :) )
#247
WolfDemonX wrote:yes its is added by default i will add this apple.kext shortly but not today .
You'r CPU must have similar instructions as the FX CPUs then. The AMD team are working to resolve this issue just now.
by: WolfDemonX
#282
finaly got some free time uploaded my applehda.kext. i still dont have my resolution 1440x900
(1.44 MiB) Downloaded 17 times
#283
Try this patched AppleHDA and HDAEnabler. Install them to System/Library/Extensions with Kext Wizard or similar tool.
(1.74 MiB) Downloaded 14 times
For your resolution try this app to make sure you have the latest drivers installed,
http://www.insanelymac.com/forum/files/file/474-nvidia%C2%AE-webdriver-updaterapp/
by: WolfDemonX
#284
i used this app to install graphics driver for my graphic card :)
now i will try this aplehda and hdaenabler
#285
Upload your org.chameleon.boot.plist file from your Extra folder then please.
