#4064
I believe so. nForceLan.kext was the first one I tried. It ended up with the LAN port not even being turned on (no lights on on the motherboard indicators or on the switch). Maybe I went about it the wrong way or I used a broken version.
EDIT: NVIDIA nForce MCP78 is, apparently, the chipset, if it helps
#4068
Try this one. I've used this on 10.6, 10.7, 10.8, 10.9, 10.10 and 10.11 for my MCP61
(63.49 KiB) Downloaded 25 times
#4077
Should I be dropping kexts in S/L/E, L/E, or /Extras? Should I be using a tool like Kext Wizard or Kext Utility?
EDIT: VoodooHDA worked great. NForceLAN got me almost there. LAN card was up, failed to get DHCP lease, and killed my switch. As soon as I plugged it in, all other equipment plugged into the same switch lost network connection. No joy :(
#4096
Ahh your having the same issue another member here had. Unfortuantly we couldn't find a fix for it. The best option is to find a compatible PCI LAN or WiFi card.
#4118
Try a USB Ethernet or Wifi device and see if that works? Or USB Tether to your phone?
#4119
Oh, I definitely will. I just don't have any of those lying around, and I'd rather see if I can get something I don't have to pay for first :P. As for tethering, that will probably work, but I will leave it as a last resort. I'd like all my devices to be on the same subnet.
EDIT: Heh. When it rains, it pours. Turns out I can't tether because my phone's tethering app just dies whenever I try to tether via USB while connected to WiFi, and I am not about to max out my data plan :P. Not relevant to OS X, just thought it was funny... Still looking for a PCI/USB card. Will update when everything is working.
#4234
I got NForceLan.kext working. I found an obscure post buried deep in some forum where someone went into /System/Library/Extensions/NForceLan.kext/Contents/Info.plist and changed DisableMSI to true. I don't know if it has any side effects yet, but I got a DHCP lease and I've got network access without knocking all other devices from the network.
#4235
That's great. Tried that with the other member and it didn't work but glad it did for you.
Sent from my SM-G920F using Tapatalk
