by: evy0311
#3935
Im trying to install el and hopefully If there are minimal to no glitches and bugs, I'll install it as my main operating system.
Here's my problems:
I created the install USB using Yosemite niresh. It worked great and the first time I installed it it worked fine. Then I configured things wrong and got into a mess, so I tried to install it again on an internal hard drive. It worked, but then I got kernel error. If I didn't boot into safe mode (-x) I would get an "invalid kernel opt code". I even tried using a different kernel I found on the forum but it too did not work.
So what should I do? Should I recreate the installer in case something has become corrupt on it? Im running an API With a graphics card but read APUs can have issues. Which kernel should I use?
#3946
For starters don't use niresh... Use my VM image to make a proper installer.
by: evy0311
#3949
I cant use VMWare... every time i try to install VMWare on my actual PC it never works. The installer hangs. Im gonna install Niresh on my HDD to run the OS X AMD Installer found on this forum. Hopefully thatll work. I just need to find a kernel thatll work with my APU.
#3954
Find a copy of TransMac and download this, viewtopic.php?f=23&t=404
The kernel is already there all you have to do it restore it to USB and boot.
by: evy0311
#3956
Okay I will do this and let you know how it goes. Thank you so much!!
