#3903
Which kernel did you use?
Sent from my SM-G920F using Tapatalk
#3908
Ok try booting with -x
#3910
Try this kernel instead then and boot with UseKernelCache=No
http://amd-osx.com/files/archive/10112R2.zip
#3914
Shaneee wrote:Try this kernel instead then and boot with UseKernelCache=No
I put that kernel in /System/Library/Kernels and tried booting. With "UseKernelCache=No -x" and now I get this error that seems to loop.
#3917
Give this a go, viewtopic.php?f=23&t=196
