by: fizi
#3797
Hi, I can't install my OS. It stucks at 17 minute. I waited more than 1,5 hour but It still stucks.
Photos:
http://imgur.com/wpVv9K9
http://imgur.com/XVkK5Om
#3801
What kexts have you added? Also this can be common especially if you're using a USB Fix. It will install eventually.
#3803
Ok leave it to install and if it still gets stuck at 17 mins change the log view to show all logs and scroll up to the last message relating to the installer. The error about the font is common for El Capitan so you can ignore that.
by: fizi
#3804
Install stucks on.
Photo included.
#3805
What's below the extraction of BaseSystemResources ?
#3807
Ok the file may be corrupt. Extract the BaseSystemResources.pkg from the Packages folder and copy it to the USB again. If it still sticks there just leave it for a bit longer. I've waited almost 3 hours on an install once :shock:
#3809
It will eventually install :thumbup: You need patience especially with an AMD hack :D
