by: hamannz
#3709
Well I haven't found any concrete guide on how to install OS X.
So far I've downloaded the VMWare img, and I have it running. Now how do I Install OS X as host OS?
My hardware:
AMD FX-4100
16GB DDR3
ASUS Crosshair V Formula-Z
Nvidia evga GTX 550TI
WIFI - TP Link - Model: TL-WN881ND
Thanks!
#3710
hamannz wrote:Well I haven't found any concrete guide on how to install OS X.
That's why you're here :thumbup:
You can find a tutorial to make the USB installer here, viewtopic.php?f=24&t=20
And for after the install here, viewtopic.php?f=24&t=80
by: hamannz
#3711
I have the "Files", but i can't seem to find the "Install OS X El capitan"
Also, is a 8GB USB enough?
#3712
8GB should be ok yes. In your VM download the Install OS X El Capitan app from the App Store.
by: Jaxx
#3716
hamannz wrote:So far I've downloaded the VMWare img, and I have it running. Now how do I Install OS X as host OS?
If you or someone else would be so kind to point me to where I could download this VMware image, I would be very grateful. I have no intent of installing El Capitan as my host operating system, but I would like to have an OS X virtual machine on my AMD machine.
EDIT: As of now, I am downloading the Yosemite image. I suppose that will suffice.
by: hamannz
#3737
When I try to boot to install i get these errors. It never ends
#3745
Take a look at this page and see if it helps, viewtopic.php?f=23&t=196
by: hamannz
#3762
I've copied manually the files because Kext Wizard won't work properly. No matter what "item" i select, all options are unselectable.
Now i get this.
#3772
Try boot with the flag USBBusFix=Yes
