by: Du'Islingr
#4429
Shaneee wrote:Glad you've got it sorted this far :thumbup: For the USB 2 try the bootflag USBLegacyOff=Yes
Yeah was a complete pain in the ass to get this far lol. As for USB, sometimes it cooperates and I have both USB 3 and 2 working. Other times its only 2 or 3 that works only. Its weird. Doesn't really matter too much as I have 6 3.0 ports or like 10 Usb 2.0 ports. either way I have enough ports to work with.
However I have come accross an issue with Enoch. It seems to be ignoring the fact that kernel.plist exists to force extra/extensions to load. I think it is using SMBios because I don't see an error saying it doesn't exist. I did reinstall it and everything too. This issue does only occur with the enoch I installed directly on the HDD with El Capitan. The one on my USB installer works just fine. But I did manage to workaround it by just adding the kexts to S/L/E and rebuilding the cache and let the cache be used and it works fine.
Other than that and my GPU issue which I already semi resolved it runs great. Despite the graphical issues, which I just use Dark Mode to mitigate that somewhat.
#4436
Yeah I've noticed that Enoch can be a bit picky when to actually load E/E I personally use S/L/E for all my kexts.
  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
