by: Du'Islingr
#3454
System Specs are in my signature. Using Clover Bootloader and had to install AptioDriver2Fix under uefidriver64 options in clover installer to get it to boot at all.
Edit: Dunno why the image uploaded upside down. Though it was uploaded from my phone so thats probably why. Sorry about that.
#3455
Take a look at this post here, viewtopic.php?f=23&t=196
If you don't know how to change the SMBios with Clover upload your config.plist and I'll change it.
by: Du'Islingr
#3459
Yeah I can't figure it out atm. Here it is :p
(4.1 KiB) Downloaded 34 times
#3461
Give this one a go. I've also cleaned it up a bit.
(1.5 KiB) Downloaded 45 times
by: Du'Islingr
#3464
Sweet thanks. Ill let you know if this resolves that issue. hopefully :p
by: Du'Islingr
#3473
Shaneee wrote:Give this one a go. I've also cleaned it up a bit.
Sadly this one did not resolve the issue.
#3477
Were the caches rebuilt after installing the kext? If not Clover will still load the original one.
by: Du'Islingr
#3482
I did use kext wizard to repair permissions and checked the option to clear the cache.
by: Du'Islingr
#3485
So I did it with -x and now I get this.
#3496
Kext Wizard won't build the caches for El Capitan as it doesn't know how to. Navigate to /System/Library/PrelinkedKernels/ on the USB and remove the file prelinkedkernel
Now open terminal and run the following command, this assumes the USB is named OS X Base System,
sudo kextcache -u /Volumes/"OS X Base System"
Then try boot again.
  • 1
  • 2
  • 3
  • 4
  • 5
  • 7
