#2791
And that's with the caches built and without -f or UseKernelCache=Yes ? Do you have CsrActiveConfig in the boot.plist?
by: macblack91
#2792
Shaneee wrote:And that's with the caches built and without -f or UseKernelCache=Yes ? Do you have CsrActiveConfig in the boot.plist?
Got it to work. I had to use an enoch usb bootloader. The one on mavricks didnt work
#2793
Copy the Extra folder that's on the USB to the El Capitan partition and it should hopefully work from the HDD.
#2795
Is your graphics fully enabled?
