#2781
Congrats I'm glad it's now working.
Note: Can you use the edit button rather than making multiple posts in a row please. It just keeps the forum tidy :geek:
by: macblack91
#2782
So how should I get it to boot. Mavricks and el capitan are both on one HDD. If I boot to bootloader and I try to boot it says cant find mach kernel. I want to boot el capitan tho.
Im sorry will keep it clean from now on:P
#2783
What is the bootloader version you have installed? The latest Enoch should be able to boot no problem as I currently boot 10.11.5, 10.10.5 and 10.6.8 with it.
by: macblack91
#2784
I installed the one from this forumn. Do I need to install it again on the El capitan portition?
#2785
No you only need it in the first partition. Add the following to your org.chameleon.Boot.plist on the El Capitan partition,
	<key>Kernel</key>
	<string>/System/Library/Kernels/kernel</string>
by: macblack91
#2786
Now this comes.
Tried UseKernelCache=No
-f
#2787
Try this kernel instead,
http://www.insanelymac.com/forum/topic/310796-amd-os-x-el-capitan-1011-fx-kernel-task-force/?p=2241279
by: macblack91
#2788
Now its this:D its funny how last time I just installed it and it worked zhe first time and now its such a struggle:D
#2789
You can remove the kext-dev-mode flag as that's for Yosemite. Also remove the UseKernelCache flag and try to boot. If it doesn't rebuild the caches with the command I posted previously.
by: macblack91
#2790
Sadly its still the same kp
Ok -f got it to boot. But i had to use a usb enoch bootloader, the otherone doesnt work
