#2768
Looks like you need to build the caches on the USB. Remove /System/Library/Prelinkedkernels/prelinkedkernel from the USB and run this command,
sudo kextcache -u /Volumes/"USB NAME"
Replace USB Name with the name of the USB device.
#2770
What is the name? If it has spaces you need to quotation marks.
#2773
Try renaming it to say USB Installer to the command would be
sudo kextcache -u /Volumes/"USB Installer"
by: macblack91
#2775
nope still not building a ne prelinked kernel. Im just gonna put yosmite back on:D I really dont know whats wrong with this pc. At first it worked, then it doesnt..:D
by: macblack91
#2778
Ok I think I know the Error. I downlaoded usb v3 only. But I need the files from V2 aswell or? Im now building the Usbstick again and will see if that helps
by: macblack91
#2779
Next error. Its stuck again at a gray screen. I saw the apple logo and the loadingbar but than tge screen got dark gray and thats it
