by: macblack91
#2756
Hey whats the cause that I cant enter the Installation menu.
#2758
Is it stuck there or does it reboot?
by: macblack91
#2759
Shaneee wrote:Is it stuck there or does it reboot?
Its stuck there. I used the Kernel from this forum and your USB Fix v3.
And I used your Extra folder but the SMBios from the USBFix
#2760
That's strange. Are your kexts in the Extra/Extensions folder or System/Library/Extensions?
#2764
If you have the kexts in E/E then yes the kernel.plist is needed. Also try to boot with UseKernelCache=No
#2766
That's a kernel panic. Take a picture and upload it please.
