by: NickS
#174
Cool, I'll try it this week, I just hope that there won't be some annoying USB issues.
#176
The USB issues are pretty much just with El Capitan. On that note at the Enoch bootloader try typing USBLegacyOff=Yes
by: NickS
#177
Tried. I get stuck with USBMSC Identifier, the usb starts blinking but nothing else happens. Time to get that Yosemite.
#178
One last bootflag then. USBBusFix=Yes
Try both those flags with the original USB kexts.
by: NickS
#179
You mean without the fix?
#180
Yes. If it still won't work then I do think Yosemite is the answer. El Cap has many issues even on Intel systems.
by: NickS
#181
Regarding Yosemite, any good tutorial to follow or will the video tutorial for El Capitan suffice?
#182
The setup is the same as El Capitan except two missing files that sit with the BaseSystem.dmg and chunklist but you'll see that and it doesn't matter as they don't excist in Yosemite. The files I uploaded will work for Yosemite too.
by: NickS
#183
Ok. Funny thing is that I think the Yosemite could work since 10.10.5 VMware image works without any hitch in Workstation.
#184
NickS wrote:Ok. Funny thing is that I think the Yosemite could work since 10.10.5 VMware image works without any hitch in Workstation.
It should work yes. If you have any issues post them in the Yosemite area :D
