by: NickS
#159
VMware machine works fine. The live install is what I'm having problems with.
#160
Also try adding the following bootflag,
-nodecryptor
by: NickS
#161
Still the same. With kernel that was provided in Files, after using the flag on previous page, it sent the SMC successfully initialized. However, with 10.11 rc2 kernel there are no changes at all. If I use nodecryptor flag I get same SMC message.
Edit: I've also noticed that I get HID errors. Also if I click left mouse button there is some status report, and after that the USB light no longer is on, like if the USB device is not read/recognized anymore. The USB itself is brand new.
#162
NickS wrote:Still the same. With kernel that was provided in Files, after using the flag on previous page, it sent the SMC successfully initialized. However, with 10.11 rc2 kernel there are no changes at all. If I use nodecryptor flag I get same SMC message.
Do you have a newer board with USB 3 available by any chance?
by: NickS
#163
No, this motherboard doesn't have USB3 support.
#166
Hmm it could still be a USB issue. Take a look at this from Spakk and see if it will help,
http://www.insanelymac.com/forum/files/file/521-usb-fix-for-el-capitan/
by: NickS
#169
Applied. I get this: Image What could be the reason? I'm out of ideas really.
#170
Honestly I'm not sure. If you could get your hands on Yosemite you could give that a go as its more stable for now.
by: NickS
#171
So basically the process is the same like with Installing El Capitan? Any kernel or patch that needs to applied? Enoch bootloader right?
#172
Yeah its pretty much identical :D
