by: NickS
#111
CPU: AMD Phenom II X4 955 BE
Motherboard: ASUS M4A785TD-V EVO
Chipset: AMD 785G/SB710
RAM: 6GB DDR3
Graphics: Sapphire HD7750 1GB GDDR5
HDD: 500GB Samsung, 320GB Western Digital
LAN: RTL 8211CL (nForceLAN.0.64.5)
Sound: Asus Xonar DG( In case that it doesn't work there is always on board sound)
I would really like to try getting the OS X to work with this build. The only problem beside this is that I don't have spare OS X to use to make Installation so I need to use Windows 10 to do it via TransMac somehow.
#115
You could use my AMD VMWare image to prepare your USB installer. You can find it here,
http://forum.nova-x.co.uk/viewtopic.php?f=23&t=9
by: NickS
#141
I can't boot to get to the installer I get this error Image And after that RTC error. But then again the same error above.
#142
Are you using the files I provided in the Files folder unchanged?
by: NickS
#143
Yes.
#145
Do you have AHCI enabled in your BIOS? Try adding the following bootflags,
-x PCIRootUID=1
by: NickS
#150
After booting with that flag this is what I get: Image
#152
Try this kernel instead. Replace the current one at /System/Library/Kernels/
(4.01 MiB) Downloaded 50 times
by: NickS
#154
Same like before. I don't get SMC message this time.
by: XtremeHacker
#158
OK
First, there is no use for SMC as it is built into the kernel.
Second, are you using VMWare, have you used VMWare unlocker
http://www.insanelymac.com/forum/files/file/339-unlocker/
Third, what are your settings for your Virtual Machine?
Last edited by Shaneee on Fri Jan 15, 2016 8:57 pm, edited 1 time in total. Reason: Wrapped link in [code] tags as per rules.
