by: kudo2002
#2627
Hi Everyone, After i installed El-Capitan 10.11.3 success here a list of my problems until now
my Rig:
GA-990FXA-D3
Gigabyte GTX 580
D-link DWL-520
Used a few things:
Shaneee installation tutorial
Shaneee_rc1_kernel for installation and replaced with other because a lot of applications was crashing
Shaneee_usb_fix works great in the installation+after installation
a few topics need to be read after installing it was very fun to do
Problems:
1. CPI_SMC_PlatformPlugin::start - waitForService(resourceMatching(AppleIntelCPUPowerManagement) timed out
WARNING: IOPlatformPluginUtil : getCPUIDInfo: this is an unknown CPU model
2. glitchy icons or green icons
3. it looks like my bios is reseting after every restart ( Load Last Good )
4. PS2 mouse failed to install
5. cpu doesn't run in full speed
6. cpu with Safari it's feel too heavy when watching youtube video
7. My Screen is too bright
Sorry for my bad English :D
Screen Shot 2016-06-07 at 12.11.19 AM.png (66.7 KiB) Viewed 574 times
Screen Shot 2016-06-07 at 12.09.57 AM.png (86.45 KiB) Viewed 574 times
Screen Shot 2016-06-07 at 12.04.15 AM.png (57.1 KiB) Viewed 574 times
#2630
kudo2002 wrote:Hi Everyone, After i installed El-Capitan 10.11.3 success here a list of my problems until now
Problems:
1. That's normal on an AMD machine. OS X is designed for Intel hence the kext name ApleIntelCPUPowerManagement
2. That's a current bug with the kernel that we are working on.
3. Try this in terminal to patch the AppleRTC kext to fix the CMOS reset,
sudo perl -pi -e 's|\x75\x2e\x0f\xb6|\xeb\x2e\x0f\xb6|' /System/Library/Extensions/AppleRTC.kext/Contents/MacOS/AppleRTC
sudo touch /System/Library/Extensions
4. Have you tried any PS2 kexts? If not I can upload.
5. Try the VoodooPState from our downloads page.
6. Above may fix this.
7. Are your graphics fully enabled?
by: kudo2002
#2633
3. I did try patch AppleRTC kext but it didn't work
4. I did serval kext one of them uploaded by you in another topic
5. installed and didn't solve my problem
6. didn't
7. how can I check if my Graphics fully enabled my boot flags: -v -f GraphicsEnabler=Yes npci=0x2000|0x3000 UseKernelCache=No (sometimes add USBBusFix=Yes USBLegacyOff=No PCIRootUID=1)
Screen Shot 2016-06-07 at 1.42.06 AM.png (89.71 KiB) Viewed 567 times
by: gazza35
#2636
You can tell, itll be smooth, fast and youll have lots of options for resolution in display settings, if its not installed you normally have 1024x768, mines a phenom2 system and a geforce 8800GTS and my res is at 1080i
#2639
The menu bar will be semi-transparent if your graphics are enabled. You might see a difference if you update to 10.11.5 as I see you're on 10.11.3
by: kudo2002
#2642
gazza35 wrote:You can tell, itll be smooth, fast and youll have lots of options for resolution in display settings, if its not installed you normally have 1024x768, mines a phenom2 system and a geforce 8800GTS and my res is at 1080i
it's running on 1920x1080 and got a lot of options enabled, but as you can see can't play games with that performance
Why i need good graphics because I'm also GameDeveloper :mrgreen:
by: kudo2002
#2643
Failed to login to AppStore last night, it say couldn't identify my machine :lol:
#2644
How did the PState affect your machine? It should make it smoother. Is your LAN enabled? App Store won't work without it.
by: kudo2002
#2645
Shaneee wrote:How did the PState affect your machine? It should make it smoother. Is your LAN enabled? App Store won't work without it.
PState didn't affect the machine in any way, yes my LAN enabled and it's built-in and the internet is working
by: kudo2002
#2647
What is the best Bootloader for DualBoot (Windows 10 already installed on another HDD) with graphical interface if this could be possible, I heard about Clover and it seems really good but I saw a few articles say it's not good for AMD processors
