by: gazza35
#2704
Watching this with interest, i had El Cap working, but after updating Elcap i lost Internet, Disabled My Lan and i couldnt sort it, something on the apple site about it, im waiting on 10.11.6 getting released, that should sort the bug, im meantime i dropped tp Mavericks because it works perfect for me.
Question id like to ask you both, is there a way to make CLOVER work on AMD, obviouslt its aimed at Intel, but give it another 6 months and everythings gonna be Clover only, id like to find a way to mod it for Amd use, unless its already been done, coz no matter what version of chameleon i use, my hdd will not boot when i install it, im stuck having to use usb boot stick.
#2709
XtremeHacker wrote:OK, so now I've copied your USB fix kext over to my El Cap HDD, done the above commands, but when I try to load my installation, I get the following
Error with kernel cache 0xe
waiting 10 seconds, then sleep
Try to boot without caches then or use the Clover equivalent of the kernel cache flag which is UseCaches=No
by: XtremeHacker
#2724
gazza35 wrote:Watching this with interest, i had El Cap working, but after updating Elcap i lost Internet, Disabled My Lan and i couldnt sort it, something on the apple site about it, im waiting on 10.11.6 getting released, that should sort the bug, im meantime i dropped tp Mavericks because it works perfect for me.
I'm using Clover, I don't need anything out of the ordinary to do it either.
Shanee, I tried that stuff and it won't work. :(
#2728
Ok can you access the drive to copy and rename a file? You'll need to take the prelinkedkernel file and rename it to kernelcache and place it in System/Library/Caches/com.apple.kext.caches/Startup
Clover should then boot.
by: XtremeHacker
#2731
I should be able, I'll try that, thanks.
by: XtremeHacker
#2735
All setup now. :mrgreen: Now I just need to do post-install.
#2736
Post install done, GTX 750 Ti working great, and I get to experiance of El Capitan beautiful green "stuff" too. :lol:
#2738
All working apart from the FX icons? :thumbup:
#2739
Shaneee wrote:All working apart from the FX icons? :thumbup:
Yep. :D
#2776
OK, so I installed Clover on my HDD, but when I try to boot from it I get a Boot0af error.
