#2620
Going to try getting el cap on my rig which consists of the following:
AMD FX 6300
GTX 750 Ti
Asus M5A78L-M/USB3
WD Blue 10EZEX 1TB HDD.
I'm currently preparing to install.
#2622
Need a hand let me know :thumbup:
by: XtremeHacker
#2631
Well, right now I'm using the following boot flags:
-v npci=0x3000 GraphicsEnabler=No
(I'm using Enoch), but I'm getting stuck on "Waiting for root device", I'm trying a few things right now, stay tuned......
#2637
You can try use USBBusFix=Yes with my USB fix and if it still doesn't work try Spakk's USB fix.
by: XtremeHacker
#2657
OK, so yesterday I tried clover, and It worked, I got to the installer and everything :) , but the install was stuck on 16 minutes remaining :oops: , so I opened the log, and I found this
    Mac-Pro Unknown[456]:         {
    Mac-Pro Unknown[456]:         UnicodeRange = "<__NSCFCharacterSet: 0x7ffe5b4daa90>";
    Mac-Pro Unknown[456]:         name = NotoSansBuhid;
#2658
All AMD machines get that installing 10.11 even some real macs get it. Sometimes it will stick at 16 mins. My machine sits at 16 mins then jumps to 5 after say half an hour.
Sent from my SM-G920F using Tapatalk
by: XtremeHacker
#2659
Shaneee wrote:All AMD machines get that installing 10.11 even some real macs get it. Sometimes it will stick at 16 mins. My machine sits at 16 mins then jumps to 5 after say half an hour.
Thanks, I had this on my Intel Hack, and waited it out till it finished, I guess I'll just have to wait this one out a bit (lot) longer.
by: XtremeHacker
#2675
OK, so It installed, but now when I try to load my new installation from clover, I get a black screen, and then my computer reboots, have the amd kernel in place, any ideas?
#2676
Did you rebuild the cache? If not Clover will be loading the vanilla kernels prelinkedkernel and kernelcache.
From the installer terminal, Replace Installed HDD with your HDD name.
rm -r /Volumes/"Installed HDD"/System/Library/PrelinkedKernels/prelinkedkernel
kextcache -u /Volumes/"Installed HDD"/
by: XtremeHacker
#2702
OK, so now I've copied your USB fix kext over to my El Cap HDD, done the above commands, but when I try to load my installation, I get the following
Error with kernel cache 0xe
waiting 10 seconds, then sleep
