by: Assassinale
#2557
hello,
i have currently installed os x Yosemite on my hackintosh and i would like to install El Capitan into it.
i have an AMD FX 6300 Processor and a GTX 760.
What i need to do? thanks.
#2558
First of all take a look here to see the current problems with FX on El Capitan, viewtopic.php?f=6&t=177
And is this on a separate HDD or on the same one but different partition?
by: Assassinale
#2561
Shaneee wrote:First of all take a look here to see the current problems with FX on El Capitan, viewtopic.php?f=6&t=177
this is my HDDs configuration, where "MAC OS X" is my Yosemite partition, "DATI" is a generic partition where i put data, and the SSD is used by Windows with its partitions(then i have a pen drive with Yosemite Zone).
#2564
Ok whether you installing over Yosemite or a different partition on the Yosemite drive then you can make the USB installer here, viewtopic.php?f=24&t=20
If you're installing over Yosemite I recommend formatting before installing which can be done in the installer. Or you can make another partition on the Yosemite drive and run both versions of OS X. Which ever one it is you'll need to follow this tutorial after, viewtopic.php?f=24&t=80
If you install on another partition though you can use Yosemite to copy the kernel etc rather than the installer.
by: Assassinale
#2566
Shaneee wrote:Ok whether you installing over Yosemite or a different partition on the Yosemite drive then you can make the USB installer here, viewtopic.php?f=24&t=20
ok, i will install it over yosemite, one more question, were can i take the kernel? i don't think its the same that i use in yosemite..
#2567
You can find the kernel here, http://amd-osx.com/download.html
by: gazza35
#2579
Tru using Kext wizard or one of the other many Kext utils available, some work better than others, i use Kext Wizard.
by: gazza35
#2580
if its failing to install you probably need a reboot.
