by: kudo2002
#2525
Hi, I'm new here
And got small question about PS2 mouse while installing El Capitan 10.11.5
Note:
I did try USB mouse it doesn't work also tried some usb fixes like El Capitan USB V3
my Rig:
FX-8350 blackEdition
GA-990FXA-D3
Gigabyte GTX 580
DDR3 12GB 1866
#2526
Install these kexts either to Extra/Extensions or System/Library/Extensions depending where you installed FakeSMC ect and boot with UseKernelCache=No
(175.74 KiB) Downloaded 43 times
by: kudo2002
#2530
Fix the last problem by using Shanee USB fix and my ps2 mouse didn't work after all
I succeeded to install El Capitan 10.11.3 once it reboot it doesn't boot to the system, it just reboot on loading drivers
Please help
by: gazza35
#2531
Nvidia Gfx Card by any chance??, ive experienced same issue, try - GraphicsEnabler=No, its also always wise to use Verbose boot mode, -v, just to get an idea of where the problem occurs, as for usb mouse and El Cap, thats common due to changes made in USB architecture, theres plenty of fixes for that, of which only a couple work, stick to the ones on here.
#2533
@kudo2002, Where did you put the PS2 kexts? Also you need to follow this tutorial after installation to allow it to boot, viewtopic.php?f=24&t=80
#2550
How did you apply the fix? If you've done this from Windows with a 3rd Party Application it has most likely damaged the partition table and you will need to recreate the USB.
For PS2 you can also try this kext,
https://bitbucket.org/RehabMan/os-x-voodoo-ps2-controller/downloads/RehabMan-Voodoo-2016-0529.zip
