by: inews
#2283
I got Kernel panic nanoseconds in first boot after el capitan installation ,
Asus M5A97 le rev 2.0 / Amd FX 8350/ R7 260x
10.11.2 OSX version. When installation finish I copied kernel to HDD .
Do I have to do anything , or what is the issue?
Thank in advance
#2287
What is the kernel panic? Can you take a picture and upload it.
by: inews
#2290
Now I fixed it's seem I need to put extra folder in the hard. Now kernel panic gone. And I got USB looping issue same as in installer , do I have to apply for USB v3 fix of yes ? How I can by terminal ?
#2294
Try with this USB fix instead, viewtopic.php?f=23&t=196 There are less files to copy.
by: inews
#2299
With this I got still waiting for root when I tried in installer , anyway I will each kext one by one? I hope to not get same error as in installer , if I got then I have to copy the whole kexts of USB v3 . Is there any terminal trick do the job
#2302
You can make a folder in the root of your USB with the kexts. Say the folder is called USBFix use the following to install the,
cd /Volumes/"OS X Base System"/USBFix
ls
This will give you a readout of all the kexts in the folder. From there you can use the following to copy them,
cp -R IOUSBFamily.kext /Volumes/"YOUR HDD NAME"/System/Library/Extensions/
IOUSBFamily.kext is an example you need to do this for each kext you see in the list from ls. Also be sure to replace "YOUR HDD NAME" with the name you gave it.
Then run the following to build the caches,
kextcache -u /Volumes/"YOUR HDD NAME"/
