by: gannman13
#2306
The last thing was extracting the BaseSystemResources.pkg and that was 40 minuets ago
EDIT: also a failure to setup sound about 20 minuets ago
#2307
BaseSystemResources isn't a large file. It may be corrupt. Try to copy the package again.
by: gannman13
#2308
Just incase im fully recreating the installation USB from scratch (re-downloaded from the app store and all). Thanks for your help so far
#2309
If that's what you want to do ok. Just make sure everything copies over correctly and if you unplug the USB eject it properly.
by: gannman13
#2310
I tried again and had similar issues. Im thinking I might just stick with 10.10 especially if there are issues on 11 for fx processors...
#2312
If that's what you want to do. The Yosemite kernel works great on FX.
Sent from my SM-G920F using Tapatalk
