by: gannman13
#2232
Hi,
I followed the steps in the preinstall video and the usb fix v3 however when I get into the setup from USB my mouse doesn't work. However, the keyboard does and I had them both plugged into the same USB controller. What am I doing wrong?
Thanks
#2235
This is a common error specifically with AMD machines just now. Try this USB fix instead, viewtopic.php?f=23&t=196
#2240
If it still won't work try your mouse in every USB port just to be sure.
by: gannman13
#2281
Ok so I got in with mouse using that guide + using
USBBusFix=Yes
. The installer is running VERY slowly and beachballing a bit but seems workable.
Thanks for the help
#2285
Yeah for some reason the El Capitan installer is buggy but it should install ok though.
by: gannman13
#2291
OK, still having problems. The installer went on for ages and when I checked the log it had
tsplicedfont failed creating descriptor for
followed by some more script over and over again.
#2295
Yeah that's common even on real Macs. Just give it some time.
by: gannman13
#2304
OK, I left the installer running for an hour and its not moved, doesnt seem right to me....
#2305
I've waited two hours on a machine waiting for it to install once. Open the log and change it to show all messages and scroll till you find the last message relating to the installer not the font error and tell me where it's at.
