#2238
I recommend you try with Yosemite. At least then the installer might load and install giving us a chance to look at your graphics and see if they can be enabled.
#2244
The two are pretty much identical apart from Yosemite doesn't have AppleDiagnostics.chunklist or AppleDiagnostics.dmg which is fine so just use the El Capitan tutorial with the Yosemite kernel.
by: Mistah_Sheep
#2268
Gets stuck on AppleKeyStore starting but this time it is after FakeSMCKeyStore started. this is with no flags and a clean install of Yosemite.
#2270
Is the npci bootflag in your boot.plist? Remove it and try again. Also try acpi=off
#2276
What is GraphicsEnabler set as? Try the opposite. I really do think it's the GPU causing issues. If there was a dedicated card it should load up. Even if you can borrow one to try.
by: Mistah_Sheep
#2280
GraphicsEnabler= Yes and No still hang. The patcher does mention the card when using GraphicsEnabler=Yes (near the top)
#2284
Hmm try to remove all the ATi/AMD kext in /System/Library/Extensions
