#2213
I see your accessing the forum using 10.11.5 Is this a VM or a rea Mac? You could possibly install onto the HDD that way. Switch the kernel then put the HDD back into your AMD PC. I'm not sure what is causing this stall. I've had it a couple times on Yosemite and using -f (UseKernelCache=No) normally fixes it.
#2215
Hmm in that case probably best to leave it as not to mess with it.
Lets experiment to find a fix for this issue. Navigate to /System/Libray/Prelinkedkernels and remove the prelinkedkernel file. Now install the AppleKeyStore kext that your Mac uses into your USB. Maybe there is a corrupt kext.
by: Mistah_Sheep
#2216
I replaced the kext from my Mac and even replaced FakeSMC (because that's where it gets stuck now) but still AppleKeyStore starting and FakeSMCKeyStore: started
#2217
Try PCIRootUID=1 as a bootflag. Also what GPU do you have?
#2219
Try with GraphicsEnabler=No
#2222
Are you using the built in ATI graphics? That may well be the issue. Looking at the Veriton L410 it doesn't have dedicated graphics.
