#2171
Very strange. Which version of El Capitan is this? The installer could possibly be corrupt.
#2179
Yes that's the latest one. Can you try to recreate the USB. I may well be corrupt somehow.
#2186
Unfortunately this isn't a very well documented problem. Try with the following bootflags,
dart=0 cpus=1
#2192
Try using the latest version of Enoch to boot. It has recently been updated,
http://www.insanelymac.com/forum/files/file/71-enoch/
by: Mistah_Sheep
#2206
No progress and it might have even gone backwards as it is stuck at AppleKeyStore starting again but maybe the update of Enoch undid some of the steps taken earlier.
#2208
Try this SMBios instead. Replace the current one in the Extra folder.
(735 Bytes) Downloaded 15 times
