#2157
Ok take both FakeSMC and NullCPUPowermanagement and install them to /System/Library/Extensions with Kext Wizard and then run the command from here again, viewtopic.php?p=2143#p2143
Also remove the Extensions folder from Extra.
by: Mistah_Sheep
#2158
Still the same thing when booting into OS X but the kernel patcher has some different messages now (mainly about the extensions)
#2161
Ok try this kernel then. You might need to rebuild the caches for this kernel but try without first. Use the bootflag UseKernelCache=No
(4.09 MiB) Downloaded 18 times
by: Mistah_Sheep
#2163
With the new kernel it now boots past the AppleKeyStore but it will now get stuck at FakeSMCKeyStore: started. Is rebuilding the kernel caches running the same command from before?
#2165
Yes it is. Remember to first remove the old prelinkedkernel file.
#2168
Very strange. Try booting with -x UseKernelCache=No
