by: Mistah_Sheep
#2125
I have just finally gotten a live USB for El Capitan following the guide here on the forums but I'm running into a small error (this is my first time Hackintoshing so bear with me).
When booting from the USB I boot from OS X Base System with no arguments and everything goes smoothly until I get to "AppleKeyStore starting" and the process gets stuck. I'm not sure if it just takes awhile or if this is just a problem with my setup. Either way is there a fix for this?
#2131
Go back to the OS X you created the USB in and run First Aid on the USB with Disk Utility then reboot.
#2143
Ok back into the OS X you've got and navigate to the following folder on the USB, /System/Library/PrelinkedKernels/ and remove the file prelinkedkernel
Then run the following command from terminal, ( If your USB is named something other than OS X Base System then use that name instead. )
sudo kextcache -u /Volumes/"OS X Base System"/
#2148
Did it successfully recreate the prelinkedkernel file on the USB? Remove -f and UseKernelCache=No form the boot.plist if they are there.
by: Mistah_Sheep
#2150
It did recreate the prelinkedkernel file and I removed -f from the boot plist but the only thing that remains is -v ncpi=0x3000. The log shows a lot less stuff (due to removing the -f) but still gets stuck at the same place.
#2151
Ok install this version of FakeSMC to your Extra/Extensions folder and try again.
(38.09 KiB) Downloaded 15 times
#2155
Hmm I don't see FakeSMC loading. Can you upload your Extra folder in zip format please.
