#2047
Please use the edit button to prevent multiple posts in a row to keep the forum cleaner please.
Hope the install goes well. Remember if you open the Installer Log it cancels the auto reboot.
by: Triconix555
#2048
Shaneee wrote:Please use the edit button to prevent multiple posts in a row to keep the forum cleaner please.
Thé installation is done but after moving kernel and extra folder and I try to boot ont thé mac installation I see thé apple logo with statusbar then disapear and the pc bust reboot did I do something wrong ?
#2049
Did you perform the commands to rebuild the prelinkedkernel after? If so try to boot with UseKernelCache=No
by: Triconix555
#2051
rm -f /Volumes/"Your HDD Name"/System/Library/PrelinkedKernels/prelinkedkernel
kextcache -u /Volumes/"Your HDD Name"
This commands ? I did bit there where à lot of things like apple.... not found etc ?
#2058
Yes those commands. The errors about missing Symbols are normal with a modified kernel.
Did you try booting with UseKernelCache=No
