by: uridi0t
#2054
How do I know which kexts are being used for backing them up? There too many kexts in extension folder. Thanks
#2060
uridi0t wrote:How do I know which kexts are being used for backing them up? There too many kexts in extension folder. Thanks
You only need to backup original apple kexts if you've modified to work like AppleHDA or a graphics kext. If you haven't modified or changed any you don't need to back them up.
by: tmartin
#2063
Do you think I'd be able to use Beyond Compare to compare my current extensions folder to the one from the 10.11.4 installer??
#2065
I'm not sure but you shouldn't need to. The installer doesn't include all the extensions anyway. Like I said unless you've physically modified an original Apple kext or replaced it do you need to worry about the Extensions folder. If you've not done this then just the kernel is all that will need replaced.
by: tmartin
#2069
Shaneee wrote:I'm not sure but you shouldn't need to. The installer doesn't include all the extensions anyway. Like I said unless you've physically modified an original Apple kext or replaced it do you need to worry about the Extensions folder. If you've not done this then just the kernel is all that will need replaced.
Perfect. I'll try the same method you did. Sounds easy enough. Thanks!
by: uridi0t
#2081
I just updated from El Capitan 10.11.4 to 10.11.5 on my test drive. It seems 10.11.5 working okay so far. Just update it, then replace the kernel and install USB V3 and fix permission.
by: Jordi
#2095
Successfully update to 10.11.5, copy kernel and install nvidia all is working
