by: chadkdxl
#59
I follow the preiinstall tutorial and everything is find, but in installer I cannot see my SATA disks.
If i connect USB HDD to PC I can see USB HDD in installer.
Can u help me?
Thank you for preinstall tutorial!!
My PC:
CPU: AMD Phenom II X4 955 Black Edition
MB: ASUS M4N68T V2 - nForce 630a
RAM: Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 1600 XMP
GC: Sapphire HD 6790 1GB GDDR5
#60
Hello.
Please can you list your system specifications so I can help.
by: chadkdxl
#61
Shaneee wrote:Hello.
Is it enough?
#62
Yes you have a nForce chipset which means you will need to add this kext into the Extra/Extensions folder for your HDDs to show.
(42.76 KiB) Downloaded 47 times
by: chadkdxl
#63
Awesome!! Its working really thank you!!
#64
No problem. If you have any issues once its installed please post here, http://forum.nova-x.co.uk/viewforum.php?f=26
Also don't forget to copy the kernel and Extra folder to your installed partition.
