#1653
Yes that is common. If you save it and upload it when it fails I will sift through it and find the error.
#1656
PRO>KOMP.< wrote:If I format SSD before install it will crash, now I don't format and its in loop.
I will now start again installation and format SSD, and post log of crash...
Shaneee wrote:Yes that is common. If you save it and upload it when it fails I will sift through it and find the error.
This is exactly what mine did. It wouldn't let me save the log.
#1845
What did you do different from before when it was booting?
#1853
Try running First Aid on the drive from within Disk Utility then try boot again.
