#1974
Upload your config.plist please.
by: Coaleb
#1977
https://www.dropbox.com/s/mvswwhly2kamntz/config.plist?dl=0
I didnt know what i was doing with this one.
#1979
Ok try this one,
(1.95 KiB) Downloaded 11 times
by: Coaleb
#1981
It stopped at hpet
#1982
Where? Can you take a picture where it stops.
by: Coaleb
#1983
#1984
Ok open your config and remove npci=0x3000
by: Coaleb
#1986
Well it was just a random crash on that launch. I had to readd npci=0x3000. Still no usb input though.
#1988
Do you have a DSDT? You could try the USB DSDT Fix within Clover. I've added the DSDT fix to this config not sure if you actually need a DSDT file in place as I'm not too experienced with Clover.
(1.97 KiB) Downloaded 13 times
by: Coaleb
#1989
I think thats my issue is. I have no idea how to set up these configs for clover. There needs to be an easy way to set one up
