#1844
You will still need to install Clover after that fix. It only copies a new boot.efi file for Clover to read.
by: Coaleb
#1859
I installed clover after the fix was applied. It still chose to boot with enoch though. Is there a way to get rid of enoch first?
#1863
Did you boot with the HDD where Clover was installed? Did you install Enoch to the ESP (EFI)? The ESP will be used to boot first so if Enoch is there and Clover is just on the HDD partition then it will boot with Enoch. Make a bootable USB with Enoch as a backup for testing and install Clover to the HDDs EFI Partition.
by: Coaleb
#1876
So I figured out how to get it working but now it won't boot. It shows the apple logo and freezes.
#1877
Boot in verbose and see where it freezes.
by: Coaleb
#1878
Okay I will and let you know the results
#1879
If it gets stuck on the graphics (IOBluetooth error) Try injecting a FakeID for ATI. Try 0x67B01002
by: Coaleb
#1891
Alright sorry about the delay but It gets stuck at the pci configuration screen. I may have to wait longer but it keeps getting stuck with nothing showing up
#1897
Add npci=0x3000 as a bootflag and it should pass that.
by: Coaleb
#1965
Well it booted but now I have no usb access at all XD
