#1802
Yes you can use GPU-Z
https://www.techpowerup.com/gpuz/
by: Coaleb
#1807
https://drive.google.com/open?id=0B45-DnC58r11d0JMTEdKRlFpeDQ
This is everything that gives probably will help a lot more than what I gave before.
#1820
I think you would be better using Clover to get this working. You could possibly use FakeID to get it recognised as another AMD Card.
by: Coaleb
#1824
Alright I have tried before to use clover and I haven't gotten it to work. I even tried a reinstall to get it working and nothing.
#1825
Did you just get a black screen after selecting to boot?
by: Coaleb
#1826
Yeah I did
#1827
I've fixed that here, viewtopic.php?f=23&t=184
by: Coaleb
#1828
How do you install that. I tried installing it first then installing clover and it won't boot still. Also how do I get rid of enoch all the way
#1829
Install it to your El Capitan partition and try to boot with Clover.
by: Coaleb
#1836
I installed to my el capitan partition and it just booted with enoch still.
