by: Coaleb
#1576
Whenever I use chrome on the hackintosh it starts to flash a lot and its hard to use. The only reason I am using it is because safari will launch and will crash after I try typing.
#1577
Are your graphics fully enabled?
If yes then go to Chrome > Preferences > Show Advanced Settings > And untick Use hardware acceleration when available.
by: Coaleb
#1723
I did that and it still is flashing. I dont think my graphics card is fully enabled eihter.
#1730
Is the menu bar slightly transparent? What does system information show?
by: Coaleb
#1740
https://www.dropbox.com/s/ebr4954rblillt7/Screen%20Shot%202016-05-07%20at%203.32.03%20PM.png?dl=0
Here is what it shows me
#1746
Ok it shows 3MB so I would think that it isn't working right. Please run this app and find the device ID of your GPU.
http://amd-osx.com/files/DPCIManager.zip
by: Coaleb
#1754
1002, AAC0, 1682, AAC0, Advanced Micro Devices, Inc. [AMD/ATI], Tobago HDMI Audio [Radeon R7 360 / R9 360 OEM]
1002, 6658, 1682, 7360, Advanced Micro Devices, Inc. [AMD/ATI], Bonaire XTX [Radeon R7 260X/360]
This is what I found close to what includes my gpus name is.
#1765
Ok I've modified the AMD kexts to try and give GPU support. Please install them with Kext Wizard or KCPM Utility and repair permissions.
(5.54 MiB) Downloaded 15 times
by: Coaleb
#1773
That stopped me from launching.
#1774
Boot with GraphicsEnabler=No -v Where does it stop?
