#1841
by: rudebwoy
#1861
I installed everything, but it does not work.
the system will continue to restart on its own.
but if I install enoch 2468 on El Capitan HD functioning?
or advise me to install El Capitan alone, without dualboot (with Yosemite)?
#1865
If your system boots fine with r2468 then just stick with that :)
#1885
Your system boots and works with Enoch r2468 correct? If so just use that then. If it boots fine then there is no need to update Enoch.
by: rudebwoy
#2370
I installed the enoch 2468 on El Capitan HD, but the result is always the same.
I have repeatedly resetting
you say that installing only El Capitan (Yosemite with no dualboot) solve?
#2380
Are both installations on the same HDD or separate?
#2429
Install Enoch to the Yosemite partition then or you can choose to install it in the ESP (EFI) partition of the drive. I have Enoch r2795 installed on the ESP of my El Capitan drive but it also boots my Yosemite and Snow Leopard which are on a different drive with no bootloader installed to it so I know it can work on all versions of OS X.
