#1445
Enoch r2795 boots Yosemite just fine. As for the El Capitan did you copy the kernel to the HDD once installed?
by: rudebwoy
#1597
I have since installed enoch 2795 of Yosemite but does not start in normal mode. you start in safe mode.
while on el capitan I copied the kernel but the result is always the same. I continuous reboots. I tried to insert all bootflags but will not start.
what can I do?
#1598
What stops Yosemite booting in normal mode?
Use the following bootflag for El Capitan, UseKernelCache=No
by: rudebwoy
#1618
the error when starting Yosemite is this FSEvents watcher dbfseventsd (bootflag -v).
I managed to fix everything and installing the old enoch (with bootflag -x).
I tried booting of El Capitan with UseKernelCache but the result is always the restart.
#1628
Please upload your org.chameleon.Boot.plist for El Capitan.
by: rudebwoy
#1647
this is org.chameleon.Boot.plist for El Capitan (USB boot).
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>CsrActiveConfig</key>
<string>103</string>
<key>Kernel Flags</key>
<string>-f -v npci=0x3000</string>
</dict>
</plist>
unfortunately I can not boot the system and create an account for el capitan in order to have the system.
#1650
Remove -f from there and try to boot. You shouldn't need to enter any other flags.
by: rudebwoy
#1763
org.chameleon.Boot.plist the El Capitan I sent you the USB Installer.
unfortunately on HDD EL CAPITAN have not created a org.chameleon.Boot.plist file.
I can only install El Capitan. I can not configure it (then create accounts, passwords, etc.).
I thought that perhaps it is a kernel problem.
what do you say?
#1771
You should have copied the Extra folder to the El Capitan HDD once it was installed. This contains the boot.plist.
Did you install the USB Fix for the USB Installer? You'll need to do this for the HDD as well if you can't configure it due to the mouse not working.
