by: rudebwoy
#1278
Hello guys,
I have a problem with OS X 10.11 on AMD.
I installed everything correctly as your video
https://www.youtube.com/watch?v=u7AFcC2et6U
after installation I go to boot the system to be able to configure
(username, password, etc.) but my pc restarts continuously without getting
into the final configuration screen.
I state on the PC is also installed Yosemite (on partition different) with
Chameleon r2463.
what's the problem?? how can I fix?
the configuration of my pc
MSI A68HM
AMD A4-4020 APU
8 GB di RAM
Asus AMD Radeon HD 5450
thank you
regards
#1282
Did you copy the kernel and Extra folder over to the installed OS? Because you have Yosemite already there you can use that to put them in place. I'm not sure if the Chameleon r2463 will boot 10.11.x but try. You may need to upgrade it to Enoch but don't worry it boots Yosemite too.
by: rudebwoy
#1286
I've copied all the files as indicated in the video.
then install enoch 2795 Yosemite HD and try to start ada El Capitan?
I have to use bootflag or not?
I have already tried to start El capitan with Enoch in 2463 but will not start, it does not come out even the apple and the loading bar.
by: Chad
#1288
Have you followed the Post Install Preparation yet? You can find the guide here:
http://forum.nova-x.co.uk/viewtopic.php?f=24&t=80
#1292
rudebwoy wrote:I've copied all the files as indicated in the video.
Search for KCPM Utility and use it to repair and rebuild the permissions on your El Capitan partition from Yosemite then try to boot again.
by: rudebwoy
#1314
ok with KMPC repair and rebuild the permissions, but I must still update Enoch from 2463 to 2795?
I was wondering do I have to Enoch installed directly on Yosemite and selecting the HD Yosemite, is this correct?
Chad also try using your method and let you know if it works.
thank you
#1316
Yes install the latest Enoch to your physical OS X Drive. Yosemite is in the VM and you don't need to change anything in it. We are just using it to get El Capitan up and running.
#1436
I can't help if I don't know how it doesn't start? Can you give some more information.
by: rudebwoy
#1439
after installing enoch 2795 Yosemite of the message displayed is FSEvents watcher dbfseventsd (bootflag -v).
I managed to fix everything and installing the old enoch (with bootflag -x).
however if you start el capitan the result is the continuous reboots (even with bootflag -v) and I can not display an error code.
