#20930
Try this,
https://mega.nz/#!D4AwHY5Q!AJ0swqiHr-vm72t3CUz8vAMi_NiGHKbU-u3DD6gv8Vc
by: gothistanic
#22034
Hello Team.
I have downloaded VMWare files for El-Capitain. The installation went Ok.
But It's kind slow, infact when i move the mouse or open an application it's kind laaging.
I installed the vlware tools and still slow; So what should I do to make it run like a charm :)
The VM config was 4 Go Ram and 4 Processors.
#22037
The problem is that it's a VM. macOS was never meant to be emulated on a Windows VM. The Yosemite version runs much smoother though.
by: gothistanic
#22039
Shaneee wrote: Mon Jun 12, 2017 9:58 pm The problem is that it's a VM. macOS was never meant to be emulated on a Windows VM.
So if it is tha case, why people use macOS on VmWares ?
in another hand, as i have a PC with AMD phenom X6 1255T and AMD Hd6870 Graph Card, could I install it as standalone OS (not using the VMware) and in case of yes could you please tell me from where could I download it and how install it.
Thank you in advance
#22040
Yeah that system will run El Capitan physically. Look in the Tools section of the forum for El Capitan Installer for Windows. :thumbup:
